- Sat Jun 24, 2006 7:59 pm
#14952
OK, I need to add a serial connection to a cable modem that I have.
I've noticed a couple of parts on the site that I think will suit my needs, but I have a question about some of them.
I know that I need to convert from TTL (0v for logical 0, and +5v for logical 1), to serial.
Now, this part:
http://www.sparkfun.com/commerce/produc ... cts_id=316
is the MAX232 chip, which will do just that.
I also found it on a PCB:
http://www.sparkfun.com/commerce/produc ... cts_id=449
Then, I also found this:
http://www.sparkfun.com/commerce/produc ... cts_id=133
my question is, will the last product work in the same way as the first 2? (the first one i would have to finish myself, i know)
The reason i ask is because in the last item, the description says that basically all new computers use EIA-232 standard, which uses 0v and 5v, just like TTL. This is what confuses me, because wouldnt this render the first two products useless?!
Is there an error in the description, or am I just reading this wrong?
Any help is GREATLY appreciated, as this is my first attempt at doing anything with hardware (I have an Altera UP2 board, which has 2 FPGA's on it, which I've never used before, and would like to start using, any help with what to do with these would be greatly appreciated also!)
Thanks much!
~Nate
Now, this part:
Thanks much!
~Nate
