- Fri Mar 18, 2011 6:38 pm
#123117
Hi everyone. Often when I breadboard I have switches and other controls that I need to use. I am looking for a mounting method that is more physically secure than allowing the control to dangle from the breadboard by the wires connecting the control to the breadboard. Ideally I would like to use metal angle brackets I can fasten to a piece of wood, attach the switch, pot, pilot light, to the angle bracket. With a small soldered or solderless breadboard attached to the wood I can add the button debounce circuit, etc. Connection to the switch breadboard to the Arduino (or any other project) can use a technology similar to the Patch Shield http://www.adafruit.com/index.php?main_ ... cts_id=256 from Adafruit.
All of this is straight forward - except finding the angle brackets or faceplate. Any ideas?
Thanks in advance for your thoughts.
