- Fri Jan 21, 2011 10:56 am
#118070
I would love to see a minimal (cheap as possible) board that had the bare minimum for implementing a useful "LUFA Bridge".
The idea is to break off the Arduino portion of the Uno leaving that nice little AVR chip and USB port to use on other projects.
The Teensy is pretty close to what I would like to see in terms of size (although smaller would be even better) and cost - plus its Wiring compatible through Teensyduino.
So you would be offering a great little microcontroller, but people like me could use lufa to reprogram it into a class compliant MIDI device gateway, for plug and play fun.
--background and clarification--
The USB boards on most of the Arduino, NetDuino, Fez, etc boards here are simply serial gateways, which can not be used to create class compliant MIDI devices or HID devices, etc. The Uno uses an AVR chip running the LUFA library (formerly MyUSB) as their serial gateway, but it can be used for these other things, if reprogrammed.
I am not sure how difficult it is to program an Uno over serial USB and use its port as something else, so the availability of an additional "LUFA Bridge" might still be useful to even these devices.
