- Mon Dec 13, 2010 4:12 pm
#115464
The HSCDANN001BA2A3 is a very accurate absolute pressure sensor from Honeywell with an I2C output and an attachment for an optional hose (the HSCDNNN001BA2A3 has no hose attachment). It has applications in almost everything, especially high altitude balloon projects because of its very accurate range of measurement over a wide range of pressures.
These are great little sensors, but unfortunately you can't find them ANYWHERE unless you order over 25. Maybe SparkFun could order some of these? They don't even really need a breakout board since they're DIP (although Honeywell DOES make SMT equivalents).
I am posting because I have tried acquiring one of these from a parts supplier and they are asking me to order at least 10. -.-
All of the pressure sensors SparkFun sells aren't rated up to very high altitudes (the MEMS ones are rated to 30 kPa, making them unsuitable for a high altitude balloon that needs accurate pressures for various reasons). These ones can go from a 100 kPa to a vacuum, giving them a pretty wide range and some great accuracy.
What do you think? These would be great for SparkFun to have as an addition to their existing pressure sensors. Plus, they're absolute pressure sensors, which makes them that much more suited for high altitude readings.
EDIT: Honeywell Silicon Pressure Sensor Guide: http://sensing.honeywell.com/index.cfm?ci_id=148494
HSC Datasheet: http://sensing.honeywell.com/index.cfm?ci_id=157750
I2C Communication Docs: http://sensing.honeywell.com/index.cfm?ci_id=156988
