- Tue Aug 31, 2010 2:58 pm
#108621
I would like a board similar to the IMU Razor 6DOF, except with digital sensors. I already have a BMA180 accelerometer, ITG-3200 gyro, and HMC5843 compass, but on three separate boards which are difficult to keep aligned with each other, and they have too many redundant pins, like a VCC and GND for each board. Basically I want these three sensors with their breakouts attached on a single board.
Make one common VCC and GND, hook together the VCC and VIO lines that need it on the ITG and BMA, expose the I2C interface and interrupt pins, skip the SPI interface, and put the 10k pullup resistors on the I2C lines. The terminal should have a single VCC and GND, a single SDA and SCL, and two lines for the interrupts on the ITG and BMA.
Make sure that the sensor axes are aligned, and make it as small as is reasonable. Long and narrow is ok, but the narrower the better, so it can fit into a small rocket tube.
