hello, new with question SIK Experiment Guide for Arduino -
kimbo
Post by kimbo » Tue Oct 24, 2017 6:31 am
hi, i'm kimbo,
and i have commenced learning;
with reference to SIK Experiment Guide for Arduino - V3.3
Experiment 3: Driving an RGB LED
https://learn.sparkfun.com/tutorials/si ... an-rgb-led
my project gets the 8 colours ok -
but it doesn't do the rainbow gradient thing.
when i look at the code, in sketch(?), i can't understand if the rainbow gradient part is working or if it is something i need to paste into the section that is doing the 8 colours, replacing that section.
i wonder if perhaps the sketch(?) is not supposed to do both - 8 colors and rainbow gradient, but does one or the other.
i am embarrassed to ask this question - i suspect it is dumb:)
cheers,
Kim
darrellg
Re: hello, new with question SIK Experiment Guide for Arduin
Post by darrellg » Tue Oct 24, 2017 9:26 am
If you want to see the colors fade, you need to change
void loop()
  mainColors();        // Red, Green, Blue, Yellow, Cyan, Purple, White
  //  showSpectrum();    // Gradual fade from Red to Green to Blue to Red
to
void loop()
The two slashes before the call to showSpectrum() cause the compiler to skip that part. Two slashes indicate a comment, and everything after them to the end of the line is ignored.
kimbo
Post by kimbo » Tue Oct 24, 2017 5:08 pm
thanks darrellg :)
