Microview & Bubble Display 7 segment = Not working
Posted: Tue Apr 28, 2015 6:44 am
Hi together,
I got stuck at an actual project at home. Besides some sensors and actors (which all are working fine), I have some trouble with the display. Hardware wiring was no problem at all, programming is a problem. Here my setup:
Microview on a breadboard, resistors, wires, bubble display.
According to the Sparkfun Learnpage (here: https://learn.sparkfun.com/tutorials/bu ... okup-guide) we have to pinout the HP Bubble Display:
Does anyone know how this can be fixed? Can this be fixed by changing the "SevSeg.h" library?
Thanks and regards,
Robert
But now comes the problem, as the Microview uses the Pins 0-6 and A0-A5. According to this page here http://learn.microview.io/intro/general ... oview.html. So after wiring and including the library in my Arduino project, I just adjust the pin declaration: //This pinout is for a bubble dispaly
//Declare what pins are connected to the GND pins (cathodes)
int digit1 = 8; //Pin 1
int digit2 = 5; //Pin 10
int digit3 = 11; //Pin 4
int digit4 = 13; //Pin 6
//Declare what pins are connected to the segments (anodes)
int segA = 7; //Pin 12
int segB = 6; //Pin 11
int segC = 10; //Pin 3
int segD = 3; //Pin 8
int segE = 9; //Pin 2
int segF = 4; //Pin 9
int segG = 2; //Pin 7
int segDP= 12; //Pin 5
But when I now try to compile my project, I get a lot of errors. And they all result from the fact, that the "SevSeg.h" library can't handle the variables filled with A0-A5. //This pinout is for a bubble dispaly
int digit1 = A0; //Pin 1
int digit2 = 0; //Pin 10
int digit3 = A1; //Pin 4
int digit4 = A2; //Pin 6
int segA = 1; //Pin 12
int segB = 2; //Pin 11
int segC = A4; //Pin 3
int segD = 5; //Pin 8
int segE = A3; //Pin 2
int segF = 3; //Pin 9
int segG = 6; //Pin 7
int segDP= A5; //Pin 5
Thanks and regards,
Robert
