Programmer with Arduino mini pro
Posted: Thu Jan 15, 2015 4:03 pm
by tester919
I got one of these from the kickstarter and am wondering if I can use the programmer for my arudino mini pro.
It seems I could do it easily with a 5v one (just plug it all in?)
Also am I able to do it with a 3.3v one? how would I proceed if I were to do that.
Re: Programmer with Arduino mini pro
Posted: Fri Jan 16, 2015 4:52 pm
by Help@GeekAmmo
Hi tester919,
You didn't mention what type of programmer you used for your Arduino Mini Pro. Normally any USB to Serial TTL converter will work properly as a programmer for the MicroView.
In our
Getting Started with MicroView, we have a diagram showing how to use a FTDI Basic as a programmer.
Does this answer your question?
On the other hand, I would recommend you to get the
official programmer from SparkFun to save you some time messing with the serial to TTL converter. It is designed to fit nicely on the breadboard and MicroView.
Cheers
JP
Posted: Sat Jan 17, 2015 5:49 am
by scotta
JP,
I believe
tester919 wants to do the opposite; use a MicroView programmer to program a Pro Mini.
tester919,
I've programmed a 5V Pro Mini with the MicroView programmer with no problems. You need to connect 5 sets of pins.
- Programmer pin 8 GND to Pro Mini GND
- Programmer pin 15 5V to Pro Mini VCC
- Programmer pin 1 RST to Pro Mini RST (not GRN, although it might work)
- Programmer pin 9 TX to Pro Mini RXI
- Programmer pin 10 RX to Pro Mini TXO
I think it would be a bit more complicated for a 3.3V Pro Mini (I haven't tried it). You probably would need 5V to 3.3V level shifters on the TX, RX and RST lines. You would also connect the programmer's 5V pin to the Pro Mini's RAW pin instead of to VCC.
Posted: Mon Jan 19, 2015 1:13 am
by Help@GeekAmmo
Thanks Scott for the clarification.
The FT231X in the MicroView Programmer is 3.3V output, should be able to work with 3.3V Mini Pro. Just make sure the 5V of the Programmer goes to the RAW input of the Mini Pro like Scott said.
Posted: Mon Jan 19, 2015 7:21 am
by scotta
JP,
Thanks for pointing out that the MicroView programmer is 3.3V compatible. I should have researched the schematic and datasheets. Good to know if I ever need to program a 3.3V Arduino!
