Microview & arduino motor shield - SparkFun Electronics
Moderators: Help@GeekAmmo, marcus@geekammo
By Help@GeekAmmo
#174712
jbesiga wrote:I would like to know if an Arduino motor shield can be used with Microview?
Someone test it?
Some pins required by the motor shield (D8, D9, D11, D12, D13) were not exposed on MicroView. You may need to use other exposed Pins to connect to the motor shield.
Hope this helps.
Cheers
JP
