The doubts about using pic16f887 to capture speed
Moderators: phalanx, Help@GeekAmmo, marcus@geekammo
ling1995
Post by ling1995 » Wed Apr 05, 2017 12:16 am
Good afternoon~all,thanks for reading my post.
I am a student majoring in electronics. Recently I am involved in a project of using PIC16F887.(this is its datasheet:
http://www.kynix.com/uploadfiles/pdf659 ... 977607.pdf )to capture the speed of machine. Unfortunately,The value is so unclear when there it’s lower that 31Hz. On the contrary,it’s normal if it’s higher that 31Hz. After that,I use lcd and pwm to try to solve this problems,it still doesn’t give the right value. Any body here can help me to analyze the troubles?
This is my main program:
The capture value:
Thank you in advance!
Valen
Re: The doubts about using pic16f887 to capture speed
Post by Valen » Wed Apr 05, 2017 10:37 am
Screenshots of code are hard to copy-paste into an IDE program to make a test program. Or are you suggesting we could hand-transcribe it?
Please post ALL the code in text form. In between
 [/ code] tags to reduce the length of your post and make it better readable.
That aside, I don't understand what kind of speed you are measuring.
scotta
Post by scotta » Thu Apr 06, 2017 9:09 am
How is this related to the Sparkfun MicroView, which is what this forum category is meant to provide support for?
