Host some data for the IoT device (server to device) - SparkFun Electronics
Everything pertaining to the data.sparkfun.com service, the phant project which powers it, and user projects which talk to the service.
By tml
#188830
Does data.sparkfun.com provide any means to host some data (ideally plaintext over HTTP/FTP) from which it can be obtained by my IoT device?
My device needs to read user configuration in order to set up data probing intervals and also check if a firmware upgrade is available.
Currently I host it at some temporary HTTP server that both hosts a config/firmware image file and handles POST requests. The configuration strings are quite short but the Intel Hex file can be of approx. 40kB in size.
I need this address to be fixed of course (so that the device checking periodically always get the right content), I could probably use some blogger.com or anything similar but I'd rather have both input and output at Sparkfun.
