Everything pertaining to the data.sparkfun.com service, the phant project which powers it, and user projects which talk to the service.
By kulve
#173323
Odd, only one topic in data.sparkfun.com..
Here's the second one. How do I limit the number of results?
In the example here: http://phant.io/docs/output/http/
The data is limited to one page but where is the meaning of a "page" documented? How many results does it contain? How do I know how many pages there are? How can I get just the latest value and not a whole page?
I haven't worked much with javascript before so if that's some standard jQuery-API, a pointer to its documentation would be appreciated.
Thanks.
By kulve
#173363
A "page" is a chunk in Phant's storage terms. It seems to default to 500k which is way too much if I need to query just for the latest value quite often.
The chunk can be defined on your own server by exporting PHANT_CHUNK.
I also had to append "?page=1" to the URL instead of using the syntax in the example.
