battery
tim.tyler
battery
Post by tim.tyler » Mon Dec 17, 2018 10:31 am
I have Sparkfun Lithium Ion Battery - 850mAh. I use them to power Microbits. However, they supply power for a short time then shut down. If I unplug the USB cable and replug it in it works for a another short time. Any answers out there? Tim
jremington
Re: battery
Post by jremington » Mon Dec 17, 2018 8:00 pm
How are you charging the battery?
tim.tyler
Re: battery
Post by tim.tyler » Tue Dec 18, 2018 11:11 am
I have a USB cable connection to a 12 port battery charger. The batteries' LED read out indicates that there is plenty of charge.
jremington
Re: battery
Post by jremington » Tue Dec 18, 2018 2:42 pm
Sorry, neither of your posts contains useful information. If you want help, you will have to provide links to all the devices you are using and post a circuit diagram.
Evidently, the battery is not being charged.
BLH
Re: battery
Post by BLH » Wed Dec 19, 2018 4:53 am
Did you see the charging warning on the batteries sales page. It requires a charger specially made for that type of battery.
"These batteries require special charging. Do not attempt to charge these with anything but a specialized LiPo charger."
I suspect its protective circuit is not allowing your 5 volt USB charger to charge it properly.
BLH
Re: battery
Post by BLH » Wed Dec 19, 2018 5:45 am
Exactly what are you using to charge the battery?
Sparkfun does have a few charging boards listed on their sales site.
By chance are you using one of their USB to Lithium Battery charging boards? What it the part number if you are using one?
