Tsunami Super Wav Trigger - Can't get it to make sound
Posted: Wed Nov 14, 2018 9:10 am
I am trying to set up a Tsunami Super Wav player to play 5 different tracks of bird songs for a museum exhibit. Visitors would push a button and the corresponding individual speakers would play that track. Ideally the track won't be able to be started again until it is finished playing.
See proposed schematic:
I am using this amp, and 8 ohm speakers, and a 5V 2A Micro USB Charger Power Adapter.
https://www.parts-express.com/dayton-au ... c--300-380
I read all of the instructions I could find, formatted the audio files to .wav, 44.1kHz, 16-bit, mono files.
They are titled as 001_A, 002_B, etc.
I loaded the most recent mono firmware on the sd card.
I loaded the .ini file on the sd card (See image)
I haven't installed this with the long speaker wires yet, and am testing it with short ones.
When I connect the ground and + of the triggers, the audio doesn't seem to go through to the output 1.
The status light blinks once quickly every few seconds.
Is there anything I may be missing?
Thanks!
-Rachel
Thanks!
-Rachel
