By paulvha
#198547
I am not sure there is a pull-up as they call out those situations specifically in the datasheet, but there are important remarks around setting EXTMODE and EXTPOLAR
(page29)
Software should only change a bit in this register when its interrupt is disabled in the VICIntEnable register, and should write the corresponding 1 to the EXTINT register before enabling (initializing) or re-enabling the interrupt, to clear the EXTINT bit that could be set by changing the mode
Software should only change a bit in this register when its interrupt is disabled in the VICIntEnable register, and should write the corresponding 1 to the EXTINT register before enabling (initializing) or re-enabling the interrupt, to clear the EXTINT bit that could be set by changing the polarity
Maybe that can do the trick.
regards,
Paul
By paulvha
#198559
did you move them in your code to before the line VICIntEnable = (1 << 14); to something like this :
#define BUZZER (1<<18)
__irq void isr()
   IOSET1 |= BUZZER;
   delay_ms(1000);
   IOCLR1 |= BUZZER;
   EINT = 0X01;
   VICVectAddr = 0;
int main()
   PINSEL1 |= 0X01;
   PINSEL2 |= 0;
   IODIR1 |= BUZZER;
   VICIntSelect = (0 << 14);
   VICVectcntl0 = 0X2E;
   VICVectAddr0 = (unsigned)isr;
   INTWAKE = 0;
   EXTMODE = 0X01;
   EXTPOLAR = 0X01;
   EINT = 0X01;    // clear any pending interrupt
   while(1)
          /*main codes*/
