Experimenting with sound: record interactively and playback programmatically
Posted: Mon Nov 27, 2017 4:59 am
I'm working on a project with the following functionalities:
I'm wondering what do I need in order to experiment with the ideas above. What I'm thinking about are a VS1063 Codec, Electret Microphone, a simple speaker and a microcontroller to orchestrate. Can you help make a list of all I need to make this project. Where can I find simple examples that experiment with such ideas?
- Record few customized messages at a trigger effect, for example press and hold a button to start recording an additional message. Sounds are supposed to be saved to playback later
- The allowed number of messages and their duration should be predefined programmatically, through setting constants in a program
- Record specific messages to use as predefined messages
- Play sounds back at a trigger effect in a customized way (e.g. in random order, over a loop, with customized time between each)
