By xandaz
#196579
I was told that one should reserve a distance of about 6.5 cm from the supply source to the output pins of the transformer. Encapsulated transfromers come built the way they do and the only reasonable way that i think it could be done would be to limit the charge on the primary pins using a ceramic capacitor of equal reactance to the resistance in the primary coil. This way i can provide the distance i need. Should i do this?
Thanks in advance.
By xandaz
#196582
Thanks a lot. The thing is that even tho i put the bypass capacitors there's still low noise. It was meant for an LM317 Regulator. Should I "snake-shape" the via between the the ripple capacitor and the filter capacitor. I made a new model wich printed today the distance is about 5 cm from the ripple to the input filter cap. I'm burning it tomorow. Hope it goes well.
tx n1ist
