wierless audio
felix45
wierless audio
Post by felix45 » Thu Aug 31, 2017 2:36 pm
hi there i was wondering if it is possible to create a mesh based network from ether bluetooth or with to creat a mesh audio system
if possible
must be able to
add or remove a node with no iteruptions
small
light waght
relitivaly long range
would like
on the base station have some from of disply that is able to show the voltage (battery leval) and signal strength of each node
esaly expandalble
idea
basicaly i have 1 main unit (base station) that will transmit the audio to the nodes each node will act like a recever and a transmitter but i i can add new nodes at any time or remove a node at any time but with no interutions to the bradcast hens the idea of a mesh desinged network
if you dont know what a mesh network is i would recomend haveing a look as it may give you a batter idea of what i am whanting
i do know there are alredy sulutions out there for this but they are ether too exspensive, too large, ned custom batterys, or not allow esay deploy of a new node
markaren1
Re: wierless audio
Post by markaren1 » Wed Sep 06, 2017 12:09 pm
Can you post a link to the commercial product that you mention please.
-Mark
