- Wed May 17, 2017 3:13 pm
#194913
Hi. I'm working on a project to control my pool with a raspberry pi. I need a relay to turn on a pool pump (230v 1.5 hp 20 amp max).
I keep seeing solid state relays like this one in my searches. https://www.amazon.com/dp/B01LYKLD1A/re ... T5DW&psc=1
One side has 2 DC terminals for the trigger and the other has 2 terminals for the AC output. But the way the wiring is at my house is I have two 115v hot wires and a ground coming from the breaker. and the pump expects two hot wires and the ground.
Can I use this relay or do I need to find another? If so, can someone show me how to wire it?
Thank you
Thank you
