- Mon May 15, 2017 3:10 am
#194863
Hi Bill and Valen
i figured out it couldn't work with the PSU as a medium in between the RS232 between two PCs. I'd probably research on more scientific ways to connect the two PCs with the PSU in between.
I've tested the continuity all all the Pins and all worked perfectly, probably the thought of using serial communication through the PSU doesn't make sense here.
Thank you guys once again!
Regards
Teo
Regards
Teo
