- Fri Mar 10, 2017 9:01 am
#193836
Howdy, I am new.
I have an LED battery powered light that operates on 4 AA batteries in series (6V). I want to ditch the batteries and use the truck 12V to power LED. I took the light apart it is pretty simple. 4 AA in series, through a switch, into a 10 Ohm resistor (did color code check), then into the 6 LEDs (they appear to be in series (kind of hard to see circuit board).
At the office we have a variable power supply. I set to 12 V and 5 Amp, then connected to the battery terminals. Did a quick on/off test and the LEDs came on. Then left it on for a second - everything ok. Decided to let it run for a bit - resistor started smoking.
I have done some research - Diodes (including LEDs) are unidirectional. They have a threshold voltage called forward voltage (get below that and no current flows). Since I had 6V of batteries, I assume the forward voltage is something less than 6 volt. I further found that once you meet the forward voltage, the diode acts basically like a short. That is the reason for the resistor (to provide a load and hence limit current).
Then did a little math V=I*R; V = 12v and R=10 Ohm. So current is 1.2A. Therefore power = about 14.2 watts.
If all my logic and math above is correct, I need a 10 Ohm resistor that can handle about 15 watts.
Is my logic, math, etc correct? It seems like a lot of power for 6 tiny lights. Further, a resistor that can handle 15 watts appears to be not terribly common - which makes me think I am doing something incorrect.
I have lots of options:
1 - Go to autozone/ebay/amazon and buy a strip LED
2 - Use an old cigarette adapter to step down the voltage
The real thing here is the education. Thanks in advance.
