- Fri Feb 10, 2017 7:25 am
#193346
This is quite a difficult project on a number of fronts, not least because brakes are mechanical and usually need hydraulic pressure to actuate. The reliability is also critical because not only could it fail to work when required it could fail so that the brakes didn't work when you out your foot on the pedal. Depending where you live, it is also questionable legally.
So while I must suggest that you do not attempt this, how about this alternative? connect your sensor so an audible alarm... You will then be able to experiment safely and explore some if the difficulties of the project without killing anybody. And it will be fun along the way!
Best regards
Sent from my iPhone using Tapatalk
