lyndon wrote:Did you ever try the piezo sensor? Curious to know if it worked in that application.
Yes, I did. I have attached 4 small piezo elements to the outside of the bell.
I have had some issues with interference in the signal I get from them. At first I used a 1M pull-down resistor on each sensor, but there was a buildup in noise on the signals.
So I replaced them for a 22k resistor and that seemed to do the trick.
The competition was yesterday and everything worked fine for the first 2 hours. After that there was a lot of noise again. The bell got quite a beating and there was probably an issue with water somewhere near the piezo elements. After a cleanup and replacing some tape, everything worked great for the rest of the day, except some people that didn't hit the bell hard enough.
For the ones that are interested in the entire project:
I created a scoreboard with three 30cm 7-segment LED displays. In the scoreboard is an arduino that drives the displays and calculates the time.
At the start is a retroreflective lightsensor, running through this starts the time.
There are 4 small piezo sensors on the bell, that stop the time.
Bell and lightsensors are each connected through a 25 meter UTP cable.
