How to power a project w 12v rechargeable
Posted: Sun Mar 15, 2015 4:06 pm
by Traxxtar
I'm having a hard time finding a solution for the following:
Need 12v 7Ah rechargeable to fit inside a large enclosure. I'd like the user to just plug a cable into a 110v wall receptacle to recharge the battery when it runs down.
I've been unable to find a ready made recharging circuit that I can install inside the enclosure. Does such a thing exist? I've seen lots of the tiny LiPo recharging circuits, but not one I can tie directly to 110v.
thanks!
Re: How to power a project w 12v rechargeable
Posted: Sun Mar 15, 2015 5:47 pm
by skimask
Really?
One of thousands...millions...
http://www.walmart.com/ip/Schumacher-SE ... g/15167359
Posted: Tue Mar 17, 2015 8:33 am
by Traxxtar
I think you misunderstood the request.
I want a 'recharging circuit' inside the enclosure, not a wall wart. I want the user to plug in a basic two-prong cable and that's it.
Posted: Tue Mar 17, 2015 9:42 am
by waltr
Wall Wart to convert the AC mains to a low Voltage DC that then plugs into your enclosure to power the battery change circuit.
This is a safe method so you or a user does not come into contact with AC mains Voltage.
Posted: Sat Mar 21, 2015 9:50 pm
by TonyRivera
Would this product work for you?
http://www.cyberpowersystems.com/produc ... I=#tab-box
I use these "fiber to the home" power packs from APC and Cyberpower to power projects that require 12VDC, 24VDC, or -48VDC in a self-contained battery and charging unit.
Posted: Tue Apr 21, 2015 4:27 pm
by johnfinx
You could get a KeyLine charger, cut off all but 2 inches of the 110v electrical cord, and solder it onto a generic computer power socket. Mount the socket through your enclosure. Then you can use any PC power cord. These chargers work well on sealed batteries, I use one on a robot project.
