- Sun Feb 15, 2015 8:13 pm
#179754
Hi Team,
Setup:
Adrunio Uno
Stepper Motor: https://www.sparkfun.com/products/9238
Setup and wire diagram used: http://bildr.org/2011/06/easydriver/
Motor pair: Red/Green & Blue/Yellow
Issue:
Motor rotates fine (just like in the video) but only in one direction
Items checked:
dir pin soldered correctly and tried different jumpers
This code does the same thing: https://www.sparkfun.com/tutorials/400
swapping the motor leads (a-b c-d to c-d a-b) changes the direction of the rotation (which means there is no issue with the motor) but shows the same issue of only one direction.
Even this code (which uses pin 8 & 9 instead of 2 & 3) shows the same issue of only one direction.
Any ideas?
Thank you in advance.
Setup:
Adrunio Uno
Issue:
Items checked:
Any ideas?
