- Fri Dec 12, 2014 10:12 am
#177639
Hi all,
Imagine a 30 cm box, with 20 bugs in it, all running around. I need to get the position (distance from a static tracker is fine) of each bug at about a rate of 60 times every second. The bugs could have something attached to them (~1-2 cm?).
Requirements:
60 updates per second - although could drop down to 30
Accuracy is pretty important here - sub 1cm.
small transmitter/tracker
must be able to track multiple 'objects' at once
sometimes bugs are on top of each other so cannot be line-of-sight
cheap - the cheaper the better (as usual )
Oh and preferable not needing a battery, or possibly a small one (or could us wireless power??? since such a small area?)
Would probably work with triangulation if needed
Have looked at:
BT - too slow and too inacurate
BLE - bluetooth low energy has same shortfalls of BT
WIFI - too inacurate?
RFID - too inacurate also?
NFC - Near Field Communiction - too slow
UWB - Ultra Wide Band - ?
So any suggestions?
Not too much to ask is it?
Jono
Requirements:
Have looked at:
So any suggestions?
Jono
