- Tue Jul 01, 2014 1:10 am
#172338
I am thinking of an art project where I want to have a laser beam going from the floor straight up to the ceiling, where a photoresistor/transistor catches the beam. I am aware that the alignment will be difficult to make as it has to be very exact. The idea is simple: when the beam is interrupted, I want to make a noise. I want to use Arduino for controlling and give out midi signals into an analog synthesizer. The best would be, if the sensor could read also if the beam is only interrupted a little, so that i can get an analog value of beam interruption and generate noise based on "how much" the beam is interrupted. The project will be exhibited in a dark room with fog, so the beam can be seen by eye. Can anyone help me out with suggestions or ideas how to approach this project? Is it the right thing to use a photoresistor/transistor for that? Any help is greatly appreciated!
