- Wed May 28, 2014 1:26 pm
#171523
Here is my situation.
I have a home theater system with cable box, stereo and TV. The TV works as I would like. TO control the cablebox and the stero system (located in a different room) I have an IR bud by the TV and an IR emitter attached to the IR detectors on the receiver and cable box.
I have a multi function remote that can control all of the devices. This works for the knowledgeable user. Unfortunately, for the less experienced user, they end up turning the cable box off when they meant to turn the TV off or the cable box and stereo get out of sync (one off and one on)
With my HTPC, I eliminate this problem using eventghost running on the HTPC. EventGhost received each of the codes and decides what todo with them.
In the setup I have problems with, I don't have the opportunity to use a PC running eventghost.
I was wondering if anyone had created a arduino type device that would receive IR codes (from a generic IR remote), and broadcast suitable set of codes to the specific devices?
For instance,
power-on - send the appropriate power-on codes to all 3 devices in sequence.
volume up/down - only send commands to the stereo and don't send to the cable box
Select Input - only send the select input to the stereo and not the TV
Thoughts?
For instance,
Thoughts?
