- Sun May 25, 2014 5:01 am
#171453
I'm making a small three digit counter, just for the fun of it. We use a small mechanical counter at work and I thought I could do that better.
The 4026 looks like the best way to implement this as I want to avoid a microcontroller. The question I have is with the 7-segment driver circuit in the datasheet (pg 7): http://www.bucek.name/pdf/4026.pdf
In my case, that means 21 transistors and 42 resistors. That would be an excessive amount, even if I were using surface mount devices and I'm not! Since I will be driving both the counters and displays from the same 5 volt source, wouldn't a simple current limiting resistor suffice? I can understand using transistors if there was a voltage difference, but that is not the case.
