- Sun Apr 27, 2014 6:22 pm
#170599
Hi, All:
I know some of you use versions of SPICE for circuit simulation, so perhaps you can shed some insight on my question.
I need a bandpass filter for an ultrasonic receiver (40 kHz) and am experimenting with a design that I found on line (attached). It works in theory but two different simulations with LTSpice give conflicting results.
1. If I simulate the circuit using transient analysis with a 100 mV, 40 kHz AC signal source, the gain is about 5, or 15 dBV. See image bandpass1.png attached. The gain drops off on either side of 40 kHz as expected.
2. If I do a "small signal" AC analysis, the circuit is reported to have a maximum gain of about -5 dB at the peak, 40 kHz.
Why the difference? All the components are linear to my knowledge, so I don't see why linearizing the circuit should have such a large effect. I've attached the LTSpice input file, but the SparkFun forum doesn't allow .asc extensions, so it is named bandpass.txt
Thanks for any insight you can offer!
