- Tue Jan 28, 2014 7:22 pm
#167830
I'm working on a small project, contains lots of LEDs, high current requirements. It needs to be battery powered. Therefore, my batteries need a high mAh. However, I'm constrained for space, so the Sparkfun 1000 mAh or higher batteries are too large. However, I was wondering if I could combine multiple smaller Li-Ion batteries in parallel to increase the overall mAh? If so, how could I go about doing that? What about the built-in protection circuity in each battery? I assume I can do this because the Sparkfun 6 Ah (https://www.sparkfun.com/products/8484) battery consists of 3 2000 mAh batteries.
Also, could I charge this hacked-together multi-cell battery with a standard lithium ion charger, like https://www.sparkfun.com/products/10217 ?
In my project I'm using a custom PCB, so I'm actually just using an MCP73831T.
Any other quirks I should be prepared for?
Thanks!
Thanks!
