- Sun Jan 26, 2014 2:20 pm
#167731
This story starts, like a lot of 'em, with someone giving me something that doesn't quite work any more usually it's something simpler, like a toaster or a vacuum cleaner, but this is a bit more high-tech.
In this case it's an iAudio portable recharger -- a battery pack in a slick little case with 4 usb sockets at one end, so you can recharge your various iGizmos on the road. Nice consumer packaging. However, this one has an issue.
At the opposite end from the USB ports is a cute little 5-led bar. The r-most LED is green and seems to indicate only on/off of power to the USB ports. The other 4 are blue and they're supposed to indicate the state of charge of the pack. Unfortunately, this blue LED bar is now acting rather strange. I've got it to light up just once, when the unit was cold; but as soon as I attach the wallwart and start charging the pack, this bargraph goes dark. Moreover, when you press the "check battery state" button when disconnected from the wallwart, you get a high pitched whine instead of light. Interesting.
I'm wondering whether someone's got a "typical" led-bar voltage display circuit I could use as a reference after I oh-so-carefully winkle out the small, fragile PCBs from the tight packaging and take a look at the LED area. I'm more of an electrician than an electronics tech so this teeny fragile stuff is new territory for me. But hey, it's a learning opportunity.
I see sparkfun offers breakout boards for USB so I should be able to test the other end of it (USB power) pretty easily. I suspect the unit still works -- the user just has no way to monitor the pack voltage. Seems like it should be a simple fix, like one chip if I'm lucky... and I hate the idea of just throwing away a serviceable product because of this apparently trivial failure.
So my naive dinosaur questions are: are these LED bargraph voltage indicators a commodity, same-old circuit that everyone (except me) was familiar with a decade ago? do they all use the same controller chip, just with different resistors for different voltage ranges? Am I right in believing this could be a pretty simple fix (so long as I don't destroy the board getting it out of the box)? Sorry to display my vast ignorance among all you experts, but we all have to start somewhere eh.
