- Wed Nov 06, 2013 7:16 am
#165298
I’m using Sparkfun’s SEN-08554 IR receiver and remote to control a clock that I’m making. However, I’m having a little trouble implementing the code for the IR receiver.
I’m using Ken Sherriff’s library and the code that Sparkfun provided:
What I’m trying to do is display my clock code in the main loop (time and date displayed from a DS3231 RTC), and then bring up a settings menu with a button press on the remote. It doesn’t seem to work.
What I’d like is for the menu function to be called when button “A” is pressed, but otherwise run the rest of the code in my main loop:
If I place my clock display code within “if (irrecv.decode(&results))”, the remote works, but the clock display code is only displayed when a button is pressed. I need that code to run when nothing is pressed! It's like I get what's either in “if (irrecv.decode(&results))” or the main loop, but not both.
I even tried handling the remote in a separate function like this
Here's my full sketch will everything:
For the ease of reading, I trimmed the code down to just the one “A” button, but all buttons are in the code. Running that code on my Mega works great. So all the hardware is fine. It’s when I add it to my clock sketch that the problems arise.#include <IRremote.h>
int RECV_PIN = 46; //pin 46 for the Mega2560
IRrecv irrecv(RECV_PIN);
decode_results results;
#define A 0x10EFF807
void setup()
Serial.begin(115200);
irrecv.enableIRIn(); // Start the receiver
void loop()
if (results.value == A)
Serial.println("A");
irrecv.resume();
However, if I do it like that, my clock code/display shows fine, but buttonAPressed is never called. I can’t figure out why.void loop()
buttonAPressed(): //call this function when “A” is pressed
irrecv.resume();
//no IR codes rec’d, continue displaying main clock display
//regular clock display code goes here
//blah
//blah
//blah
void buttonAPressed {
//display settings menu
//blah
//blah
//blah
I've tried sticking "irrecv.resume();" in various places, but it doesn't seem to make a difference.void loop()
buttonAPressed():
irrecv.resume();
//regular clock display code here
//blah
//blah
//blah
//blah
//blah
//blah
But that still doesn't get called. What am I doing wrong? I've been at this for days and I just can't get the loop to run as normal, but step into another function when a button is pressed.void loop() {
if (irrecv.decode(&results)) {
handleRemote(&results): //I think I pass "&results" here?
irrecv.resume();
//blah
//blah
//blah
void handleRemote() { //or is it void handleRemote(&results)? I think I tried various things without success
buttonAPressed():
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <DS3231.h>
#include <glcd.h>
#include <fonts/SystemFont5x7.h>
#include <fonts/Arial14.h>
#include <fonts/Arial_bold_14.h>
#include <fonts/fixednums7x15.h>
#include <fonts/fixednums8x16.h>
#include <fonts/fixednums15x31.h>
DS3231 RTC; //Create the DS3231 object
//remote
int RECV_PIN = 46; //pin 46 is for the Mega per Timer5 in the IR library
#define POWER 0x10EFD827
#define B 0x10EF7887
#define C 0x10EF58A7
#define UP 0x10EFA05F
#define DOWN 0x10EF00FF
#define LEFT 0x10EF10EF
#define RIGHT 0x10EF807F
#define SELECT 0x10EF20DF
//temp
int tempC;
int tempF;
//initial condition for menu display
boolean enterNormalMode = true;
boolean enterSettingsMode = false;
boolean enterAlarmMode = false;
boolean chimeOnHour = false;
boolean alarmIsActive = false;
//settings menu
int settingsModeButtonCount;
boolean gmtSelected = false;
boolean dlsSelected = false;
boolean chimeSelected = false;
//alarm menu
int alarmModeButtonCount;
boolean aTimeSelected = false;
boolean activeSelected = false;
//compensations
int TZAdjust;
int newHours;
int DaylightSavings;
boolean DLSinEffect = false;
//year, month, date, hour, min, sec and week-day(starts from 0 and goes to 6)
//writing any non-existent time-data may interfere with normal operation of the RTC.
//Take care of week-day also.
//DateTime dt(2013, 11, 2, 22, 03, 00, 6);
int hhRTC;
int hhAdj;
int mmRTC;
int ssRTC;
int dayRTC;
int dowRTC;
int monthRTC;
int yearRTC;
int hhGPS;
int newHourGPS;
int mmGPS;
int ssGPS;
int dayGPS;
int monthGPS;
int yearGPS;
int linkStatus;
// If you're using a GPS module:
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
// Connect the GPS TX (transmit) pin to Digital 3
// Connect the GPS RX (receive) pin to Digital 2
// If using hardware serial (e.g. Arduino Mega):
// Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3
// Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3
// If you're using the Adafruit GPS shield, change
// SoftwareSerial mySerial(3, 2); -> SoftwareSerial mySerial(8, 7);
// and make sure the switch is set to SoftSerial
// If using software serial, keep these lines enabled
// (you can change the pin numbers to match your wiring):
//SoftwareSerial mySerial(3, 2);
//Adafruit_GPS GPS(&mySerial);
// If using hardware serial (e.g. Arduino Mega), comment
// out the above six lines and enable this line instead:
Adafruit_GPS GPS(&Serial1);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences.
#define GPSECHO true
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
int enablePin = 7;
void setup()
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin, HIGH); //enable GPS
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
// the nice thing about this code is you can have a timer0 interrupt go off
// every 1 millisecond, and read data from the GPS for you. that makes the
// loop code a heck of a lot easier!
useInterrupt(true);
delay(1000);
// Ask for firmware version
// mySerial.println(PMTK_Q_RELEASE);
digitalWrite(enablePin, LOW); //disable GPS
// Initialize the GLCD
GLCD.Init();
Wire.begin(); //I think enabeling the wire library casues the problem
RTC.begin();
irrecv.enableIRIn(); // Start the IR receiver
//unhide to force time setting of the RTC
// RTC.adjust(dt); //Adjust date-time as defined 'dt' above
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
// if you want to debug, this is a good time to do it!
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
// writing direct to UDR0 is much much faster than Serial.print
// but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
void loop() {
//remote
if (results.value == POWER)
Serial.println("POWER");
syncGPSTime();
buttonAPressed();
if (results.value == B)
Serial.println("B");
buttonBPressed();
if (results.value == C)
Serial.println("C");
buttonCPressed();
if (results.value == UP)
Serial.println("UP");
buttonUPPressed();
if (results.value == DOWN)
Serial.println("DOWN");
buttonDownPressed();
if (results.value == LEFT)
Serial.println("LEFT");
buttonLeftPressed();
if (results.value == RIGHT)
Serial.println("RIGHT");
buttonRightPressed();
if (results.value == SELECT)
Serial.println("SELECT");
buttonSelectPressed();
irrecv.resume();
//RTC
DateTime now = RTC.now();
tempC = RTC.getTemperature();
tempF = (tempC * 9.0)/ 5.0 + 32.0; // Convert C to F
hhRTC = now.hour(); //used to check AM/PM status
mmRTC = now.minute();
ssRTC = now.second();
dowRTC = now.dayOfWeek();
dayRTC = now.date();
monthRTC = now.month();
yearRTC = now.year();
//pass RTC values into a new variable -
//this way one variable stores time in 24 hour mode and another that can be converted to 12 hour mode
//time is monitored 'in the background' in 24 hour mode using the RTC, but is displayed in an adjusted 12-hr format
hhAdj = hhRTC;
//convert to 12 hr mode for display
if (hhRTC < 1) {
hhAdj = 12;
if ((hhRTC > 12) && (hhRTC < 24)) {
hhAdj = hhRTC - 12;
//DLS compensation
if (DLSinEffect == false) {
DaylightSavings = 0; //DSL not in effect, don't add an additional hour
else {
DaylightSavings = 1; //DSL in effect, add an additional hour
newHours = ((hhAdj) + TZAdjust + DaylightSavings);
//not in menu mode
//time from RTC
if (enterNormalMode == true) {
//hour
GLCD.SelectFont(fixednums15x31);
GLCD.CursorTo(0,0);
if (newHours < 10) {
GLCD.print("0");
GLCD.print(newHours);
//minute
if (mmRTC < 10) {
GLCD.print(":0");
else {
GLCD.print(":");
GLCD.print(mmRTC);
//second
GLCD.SelectFont(fixednums7x15);
if (ssRTC < 10) {
GLCD.print(":0");
else {
GLCD.print(":");
GLCD.print(ssRTC);
// AM/PM indicator
GLCD.SelectFont(SystemFont5x7);
if ((hhRTC > 12) && (hhRTC < 22)) {
//PM
GLCD.print(" PM");
else {
//AM
GLCD.print(" AM");
//second line
//date
GLCD.CursorTo(0,4);
GLCD.SelectFont(Arial14);
switch(dowRTC){
case 0:
GLCD.print("Sun ");
break;
case 1:
GLCD.print("Mon ");
break;
case 2:
GLCD.print("Tue ");
break;
case 3:
GLCD.print("Wed ");
break;
case 4:
GLCD.print("Thu ");
break;
case 5:
GLCD.print("Fri ");
break;
case 6:
GLCD.print("Sat ");
break;
GLCD.print(monthRTC);
GLCD.print("/");
GLCD.print(dayRTC);
GLCD.print("/");
GLCD.print(yearRTC - 2000);
//temp
GLCD.print(" ");
GLCD.SelectFont(fixednums8x16);
GLCD.print(tempF);
GLCD.print("F");
//draw line
GLCD.DrawLine(0,51,128,51,BLACK);
//GPS status
linkStatus = (GPS.fixquality);
GLCD.CursorTo(0,7);
if (linkStatus < 1) {
GLCD.print("GPS:NO ");
else {
GLCD.print("GPS:YES");
//alarm
GLCD.print(" ALARM:");
if (alarmIsActive == true) {
GLCD.print("6:30AM");
else {
GLCD.print("OFF");
if (enterSettingsMode == true) {
GLCD.ClearScreen();
//settings menu header
GLCD.CursorTo(0,0);
GLCD.print(" ");
GLCD.SelectFont(Arial_bold_14);
GLCD.print("SETTINGS");
//draw line
GLCD.DrawLine(0,12,128,12,BLACK);
if (settingsModeButtonCount == 3) { //no option highlighted
//time zone
GLCD.CursorTo(0,1);
GLCD.print("GMT:");
GLCD.print(" ");
GLCD.print(TZAdjust);
//daylight savings
GLCD.CursorTo(0,2);
GLCD.print("DLS:");
GLCD.print(" ");
if (DLSinEffect == true) {
GLCD.print("YES");
else {
GLCD.print("NO");
//chime on hour
GLCD.CursorTo(0,3);
GLCD.print("CHIME:");
GLCD.print(" ");
if (chimeOnHour == true) {
GLCD.print("YES");
else {
GLCD.print("NO");
if (settingsModeButtonCount == 2) { //GMT highlighted
gmtSelected = true;
//time zone
GLCD.CursorTo(0,1);
GLCD.print("GMT:");
GLCD.print(" ");
//daylight savings
GLCD.CursorTo(0,2);
GLCD.print("DLS:");
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
//chime on hour
GLCD.CursorTo(0,3);
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
if (settingsModeButtonCount == 1) { //DLS highlighted
dlsSelected = true;
//time zone
GLCD.CursorTo(0,1);
GLCD.print("GMT:");
GLCD.print(" ");
//daylight savings
GLCD.CursorTo(0,2);
GLCD.print("DLS:");
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
//chime on hour
GLCD.CursorTo(0,3);
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
if (settingsModeButtonCount == 0) { //CHIME highlighted
chimeSelected = true;
//time zone
GLCD.CursorTo(0,1);
GLCD.print("GMT:");
GLCD.print(" ");
//daylight savings
GLCD.CursorTo(0,2);
GLCD.print("DLS:");
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
//chime on hour
GLCD.CursorTo(0,3);
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
//add delay to lower refresh rate on the display (remove blink)
delay(200);
//display alarm menu
if (enterAlarmMode == true) {
GLCD.ClearScreen();
GLCD.CursorTo(0,0);
GLCD.print(" ");
GLCD.print(" ALARM");
//draw line
if (alarmModeButtonCount == 2) {//no option highlighted
//alarm
GLCD.CursorTo(0,1);
GLCD.print("TIME:");
GLCD.print(" ");
GLCD.print("6:30 AM");
//alarm status
GLCD.CursorTo(0,2);
GLCD.print("ACTIVE:");
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
if (alarmModeButtonCount == 1) {//TIME option highlighted
aTimeSelected = true;
//alarm
GLCD.CursorTo(0,1);
GLCD.print(" ");
//alarm status
GLCD.CursorTo(0,2);
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
if (alarmModeButtonCount == 0) {//ALARM option highlighted
activeSelected = true;
//alarm
GLCD.CursorTo(0,1);
GLCD.print(" ");
//alarm status
GLCD.CursorTo(0,2);
GLCD.print(" ");
GLCD.print("YES");
else {
GLCD.print("NO");
delay(200);
} //end of loop
//remote functions
//GPS
void syncGPSTime() {
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
Serial.print("\nTime: ");
Serial.print(GPS.hour, DEC);
Serial.print(':');
Serial.print(GPS.minute, DEC);
Serial.print(':');
Serial.print(GPS.seconds, DEC);
Serial.print('.');
Serial.println(GPS.milliseconds);
Serial.print("Date: ");
Serial.print(GPS.day, DEC);
Serial.print('/');
Serial.print(GPS.month, DEC);
Serial.print("/20");
Serial.println(GPS.year, DEC);
Serial.print("Fix: ");
Serial.print((int)GPS.fix);
Serial.print(" quality: ");
Serial.println((int)GPS.fixquality);
if (GPS.fix) {
Serial.print("Location: ");
Serial.print(GPS.latitude, 4);
Serial.print(GPS.lat);
Serial.print(", ");
Serial.print(GPS.longitude, 4);
Serial.println(GPS.lon);
Serial.print("Speed (knots): ");
Serial.println(GPS.speed);
Serial.print("Angle: ");
Serial.println(GPS.angle);
Serial.print("Altitude: ");
Serial.println(GPS.altitude);
Serial.print("Satellites: ");
Serial.println((int)GPS.satellites);
newHourGPS = ((hhGPS) + TZAdjust + DaylightSavings);
//day of week is hard coded until a calculation can be added
//can I get this from the Time library?
//http://playground.arduino.cc/Code/Time
DateTime dt(yearGPS, monthGPS, dayGPS, newHourGPS, mmGPS, ssGPS, 6);
//add compensation here
//do not force update if data is invalid
RTC.adjust(dt);
delay(10);
GLCD.ClearScreen();
//turn off GPS module
//A
void buttonAPressed() {
GLCD.ClearScreen();
//B
void buttonBPressed() {
//enter menu in default state so no options are highlighted
settingsModeButtonCount = 3;
enterNormalMode = false;
enterSettingsMode = true;
GLCD.ClearScreen();
//C
void buttonCPressed() {
alarmModeButtonCount = 2;
enterAlarmMode = true;
GLCD.ClearScreen();
//UP
void buttonUPPressed() {
if(enterSettingsMode == true) {
settingsModeButtonCount++;
if(settingsModeButtonCount == 4) {
settingsModeButtonCount = 0;
if(enterAlarmMode == true) {
alarmModeButtonCount++;
if(alarmModeButtonCount == 3) {
alarmModeButtonCount = 0;
//DOWN
void buttonDownPressed() {
settingsModeButtonCount--;
if(settingsModeButtonCount < 0) {
alarmModeButtonCount--;
if(alarmModeButtonCount < 0) {
//LEFT
void buttonLeftPressed() {
if(gmtSelected == true) {
TZAdjust--;
//time zone changed - resync with GPS clock
syncGPSTime();
if(dlsSelected == true) {
DLSinEffect = !DLSinEffect;
if(chimeSelected == true) {
chimeOnHour = !chimeOnHour;
if(aTimeSelected == true) {
if(activeSelected == true) {
alarmIsActive = !alarmIsActive;
//RIGHT
void buttonRightPressed() {
TZAdjust++;
syncGPSTime();
//SELECT
void buttonSelectPressed() {
//set totally wrong date and time (so that a GPS sync can be tested)
DateTime dt(2011, 1, 1, 1, 1, 0, 6);
RTC.adjust(dt);
delay(10);
GLCD.ClearScreen();
