- Mon Nov 04, 2013 8:07 am
#165205
Hi all
I have a radio activated switch that is powering a siren.
The switch is powered by a 9v pp3 battery.
I wish to use a relay or similar between the switch and siren.
The switch works between 9v and 4.5 v dc the siren also works the same. But how do I select a relay that will work between those voltages? I am looking at one on farnell which works 6.75-9v but below that down to 4.5 it won't switch the relay? The siren draws 250ma and will only be on when the remote switch activates it for no longer than 15 seconds.
The reason is that the siren draws I believe too much current meaning once you have activated the switch you can not dis activate it so putting two batteries in each will then have it's own supply.
Any advice would be much appreciated
