- Mon Oct 21, 2013 9:21 am
#164692
FWIW I note that the Pro Micro uses a ATMega 32U4 which has 4 external interrupts and 2 16bit timer/counter/CCP units.
https://www.sparkfun.com/products/11098
http://dlnmh9ip6v2uc.cloudfront.net/dat ... ga32U4.pdf
ATmega16/32U4
11. External Interrupts
The External Interrupts are triggered by the INT6, INT3:0 pin or any of the PCINT7..0 pins.
Observe that, if enabled, the interrupts will trigger even if the INT[6;3:0] or PCINT7..0 pins are
configured as outputs. This feature provides a way of generating a software interrupt.
The Pin change interrupt PCI0 will trigger if any enabled PCINT7:0 pin toggles. PCMSK0 Register
control which pins contribute to the pin change interrupts. Pin change interrupts on PCINT7
..0 are detected asynchronously. This implies that these interrupts can be used for waking the
part also from sleep modes other than Idle mode.
The External Interrupts can be triggered by a falling or rising edge or a low level. This is set up
as indicated in the specification for the External Interrupt Control Registers – EICRA (INT3:0)
and EICRB (INT6). When the external interrupt is enabled and is configured as level triggered,
the interrupt will trigger as long as the pin is held low. Note that recognition of falling or rising
edge interrupts on INT6 requires the presence of an I/O clock, described in “System Clock and
Clock Options” on page 27. Low level interrupts and the edge interrupt on INT3:0 are detected
asynchronously. This implies that these interrupts can be used for waking the part also from
sleep modes other than Idle mode. The I/O clock is halted in all sleep modes except Idle mode.
Note that if a level triggered interrupt is used for wake-up from Power-down, the required level
must be held long enough for the MCU to complete the wake-up to trigger the level interrupt. If
the level disappears before the end of the Start-up Time, the MCU will still wake up, but no interrupt
will be generated. The start-up time is defined by the SUT and CKSEL Fuses as described
in “System Clock and Clock Options” on page 27.
14. 16-bit Timers/Counters (Timer/Counter1 and Timer/Counter3)
The 16-bit Timer/Counter unit allows accurate program execution timing (event management),
wave generation, and signal timing measurement. The main features are:
• True 16-bit Design (i.e., Allows 16-bit PWM)
• Three independent Output Compare Units
• Double Buffered Output Compare Registers
• One Input Capture Unit
• Input Capture Noise Canceler
• Clear Timer on Compare Match (Auto Reload)
• Glitch-free, Phase Correct Pulse Width Modulator (PWM)
• Variable PWM Period
• Frequency Generator
• External Event Counter
• Ten independent interrupt sources (TOV1, OCF1A, OCF1B, OCF1C, ICF1, TOV3, OCF3A, OCF3B,
OCF3C and ICF3)
Perhaps an upgrade in HW might make for a better solution ? Use 2 of the timers in external capture mode ? For that matter, what's the longest time expected btw any 2 sensor "pings" ? Perhaps the two 8 bit counters of the Uno are sufficient ?
ATmega16/32U4
OCF3C and ICF3)
