- Tue Sep 10, 2013 10:21 am
#163346
What would be the best way to reduce a 13.8V automobile battery down to a constant 12V to drive a device (mobile 15" TV) drawing 4 amps?
lyndon wrote:If it's a mobile TV, it will probably work just fine from 13.8VI say mobile TV that's what it was advertised as. It's a 15" computer monitor/video monitor/ATSC TV. It has a power jack input that is 12VDC tip positive.
skimask wrote:I'd go with it. Under load, that 13.8v will drop off a bit anyways, and you'll end up less than 12v quicker than you think.With the alternator and engine running? I don't think so.
magnethead wrote:DOH!skimask wrote:I'd go with it. Under load, that 13.8v will drop off a bit anyways, and you'll end up less than 12v quicker than you think.With the alternator and engine running? I don't think so.
magnethead wrote:Is it not realistic to have the engine running while watching a video monitor in the field (R/C, robotics, entertainment while on a HAM post)?True.
