- Tue Sep 10, 2013 6:08 am
#163336
Hello all,
Newbie here. Pretty new to electronics. I am working on a sculpture project, decided I would like portions of it to illuminate in a variety of colors.
After some brief research, I ended up purchasing some of these guys:
http://www.vozop.com/index.php/ws2801-d ... -leds.html
and one of these:
http://www.ebay.com/itm/SPI-RGB-LED-Con ... 25715d9503
My problem is, I can't get this setup to work. Generally what happens: plug in controller (led module already attached), module will illuminate a dim blue on all 6 led's, controller will flash through all IC's shown on the front (flashing red light behind the writing on control box), then usually all 6 led's will go full white for half a second, then completely off. Controller generally settles on one of the IC's listed (red light behind the writing on control box). Clicking through modes, IC's, speed on the controller changes nothing on the led module (still off).
Occasionally, after disconnecting and reconnecting power, I'll get the usual dim blue, followed by continuous full white until I change anything on controller, at which time led module turns off, and won't come back on again. ONCE, after disconnecting and reconnecting power, the module did it's normal dim blue, white flash, then started controlled fading through colors starting with red (I believe as it's supposed to). This only lasted for about 3 seconds, followed by turning off.
I've checked power output to the led module, 12.2v. Checking data/gnd & clock/gnd with the multimeter, I'm getting a low undulating voltage that changes depending on what mode I've clicked to on the controller (all while led module is off). If I check data/gnd upon connecting power, I get approx 5v for the duration of the dim blue, then it jumps to the low undulating voltage.
I'm at a loss. Any help you can give would be much appreciated! I will provide as much diagnostic info as I can.
Many thanks in advance!
and one of these:
