By LogicalUnit
#201966
Hi guys
I am trying to program a SparkFun Arduino Pro Mini 16Mhz/5V with a FT231X breakout. If I connect the TX pin of the programmer to its RX pin, I get an echo effect in Serial monitor. However, when I try to upload a sketch, I get the following error:
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x13
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x13
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Any suggestions?
