AS7262 Visible spectral sensor but I just need the Red
programmer1200
Post by programmer1200 » Mon Jan 14, 2019 1:48 pm
I'm attempting to retrieve only the red wavelength data off of the AS7262 Visible spectral sensor but not having the greatest luck modifying the sample code. Sample code 1 gives you a list of different functions that can be implemented and one of those include "int getRed();" but I cant figure out how to implement this into the existing sample . Thank you for the help
This is a library written for the AS726X Spectral Sensor (Visible or IR) with I2C firmware
specially loaded. SparkFun sells these at its website: www.sparkfun.com
Written by Nathan Seidle & Andrew England @ SparkFun Electronics, July 12th, 2017
https://github.com/sparkfun/Qwiic_Spect ... sor_AS726X
Do you like this library? Help support SparkFun. Buy a board!
Development environment specifics:
Arduino IDE 1.8.1
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
---AVAILABLE FUNCTIONS---
AS726X(TwoWire &wirePort = Wire, byte gain = 3, byte measurementMode = 3);
void takeMeasurements();
void takeMeasurementsWithBulb();
void printMeasurements();
byte getTemperature();
float getTemperatureF();
void setMeasurementMode(byte mode);
boolean dataAvailable();
void enableIndicator();
void disableIndicator();
void setIndicatorCurrent(byte current);
void enableBulb();
void disableBulb();
void setBulbCurrent(byte current);
void softReset();
void setGain(byte gain);
void setIntegrationTime(byte integrationValue);
void enableInterrupt();
void disableInterrupt();
//Get the various color readings
int getViolet();
int getBlue();
int getGreen();
int getYellow();
int getOrange();
int getRed();
//Get the various NIR readings
int getR();
int getS();
int getT();
int getU();
int getV();
int getW();
//Returns the various calibration data
float getCalibratedViolet();
float getCalibratedBlue();
float getCalibratedGreen();
float getCalibratedYellow();
float getCalibratedOrange();
float getCalibratedRed();
float getCalibratedR();
float getCalibratedS();
float getCalibratedT();
float getCalibratedU();
float getCalibratedV();
float getCalibratedW();
#include "AS726X.h"
AS726X sensor;
sensor.begin();
sensor.takeMeasurements();
sensor.printMeasurements();
millercommamatt
Re: AS7262 Visible spectral sensor but I just need the Red
Post by millercommamatt » Wed Jan 23, 2019 1:54 pm
It looks like the printMeasurements function prints everything. Has that worked for you?
You can try something like Serial.println(sensor.getRed());
CircuitSmarts
Post by CircuitSmarts » Sat Feb 09, 2019 7:15 am
Arduino IDE 1.8.1
void enableBulb();
void disableBulb();
void softReset();
int getViolet();
int getBlue();
int getGreen();
int getYellow();
int getOrange();
int getRed();
int getR();
int getS();
int getT();
int getU();
int getV();
int getW();
#include "AS726X.h"
AS726X sensor;
sensor.begin();
The simplest way of doing is:
#include "AS726X.h"
AS726X sensor;
int redColor =0;
  sensor.begin();
redColor = getRed();
Serial.println(redColor);
Arduino starter kits help get small developers dreaming big
https://designnotes.com/
