Odd input PULL_UP behavior
Posted: Wed Oct 24, 2018 4:44 pm
by rgsparber
I am using a Pro Micro to record analog voltages on 8 channels. It works fine except for one cosmetic issue. Unterminated inputs float and random values are recorded. I decided to turn on the pull-up resistors to get a value near 5V. Two of my ports sit at or very near 5V but the rest still float. Using a DVM, I confirmed that the pull-ups are not there. Then I changed out the Pro Micro and the same two ports are pulled to near 5V while the rest continue to float. Yet I can apply known voltages to all ports and they are recorded properly.
typical code:
pinMode(Port0, INPUT);
pinMode(Port0, INPUT_PULLUP);
Has anyone else seen this behavior?
Thanks in advance,
Rick
Re: Odd input PULL_UP behavior
Posted: Thu Oct 25, 2018 6:54 am
by paulvha
I suspect pinmapping. e.g. What happens if you use instead of Port0 (=8) : pinmode(A8,INPUT_PULLUP);
Posted: Fri Oct 26, 2018 7:08 am
by rgsparber
Brilliant! That was my problem.
Is there a way to make, for example, "A8" a variable that could be used in a GPIO statement? Would I define it as a string?
I found in the Arduino Reference section one place where they say
int analogPin = 3;
and then use it to define a GPIO as an input. However, since GPIO default to inputs, they do not use this variable to set up the port. Later they say
val = analogRead(analogPin); // read the input pin
and I can see that this function should assume the "A" in front of the number.
In the second example, they do set up the port and do not use a variable to define the port number. Too bad they don't have a note explaining this trap.
Thanks for your help,
Rick
Posted: Fri Oct 26, 2018 9:41 am
by paulvha
Good.. Now I would NOT hard code the PIN instead of the Ax... let the IDE handle that complexity and translation both during compile and execution. Using a string does not help, as part of the translation is happening during compile. Here is how I would do it ( I have only included the relevant parts of the code and NOT tested, but it did compile)
regards,
Paul
Code: Select all#define Port0 8
#define Port1 7
#define Port2 10
#define Port3 0
#define Port4 1
#define Port5 2
#define Port6 3
#define Port7 9
// put your setup code here, to run once:
//comment out these lines if you do not want unterminated ports reading 5V
#ifndef SoftwireActive //if Softwire not enabled
pullupmode(Port0);
pullupmode(Port1);
#endif
pullupmode(Port2);
pullupmode(Port3);
pullupmode(Port4);
pullupmode(Port5);
pullupmode(Port6);
pullupmode(Port7);
// put your main code here, to run repeatedly:
void pullupmode(int port)
switch(port)
case Port0:
pinMode(A8, INPUT_PULLUP);
break;
case Port1:
pinMode(A7, INPUT_PULLUP);
break;
case Port2:
pinMode(A10, INPUT_PULLUP);
break;
case Port3:
pinMode(A0, INPUT_PULLUP);
break;
case Port4:
pinMode(A1, INPUT_PULLUP);
break;
case Port5:
pinMode(A2, INPUT_PULLUP);
break;
case Port6:
pinMode(A3, INPUT_PULLUP);
break;
case Port7:
pinMode(A9, INPUT_PULLUP);
break;
Posted: Mon Nov 05, 2018 5:24 am
by rgsparber
Paul,
Thanks for your insights and sample code.
Peace,
Rick
