- Fri Aug 17, 2018 9:14 am
#200068
Hey Everybody,
I am currently using an Arduino Pro Mini 5V microcontroller with a small DC gearmotor.
Is there an "easy" way to measure the current draw from the DC motor while using the ROB-14450 Motor Driver from Sparkfun? I have also purchased the Sparkfun Current Sensor Breakout SEN-13679, but I am looking to simplify.
Can I place 2 resistors in parallel with the motor like what I show in the attached image? V=IR. So if there is a large torque load on the motor (i.e. drawing a large amount of current), then less current should flow through the parallel resistors and the voltage at Vout should be nearly 0V. With little torque on the motor, more current will flow thru the parallel resistors and Vout will be nearly 5V.
The value of the first resistor is 10K. In order to get a voltage drop of 8.5V across the 10k resistor and then the remaining 5V across the second resistor, the second resistor had to be 5.87k. TIA,
--Neal
--Neal
