Arduino Pro Mini Power During Programming
Posted: Mon Jul 02, 2018 5:50 pm
Hey All,
I am currently using an Arduino Pro Mini with the FTDI Basic Breakout. I have my circuit connected to a bunch of buttons, LED's, sensors (hall and IR), and stepper motor driver board (the A4988 Stepper Driver from Pololu).
I have my circuit on a solderless breadboard with a 12V benchtop power supply connected to the breadboard and RAW pin (on Pro Mini) while the FTDI cable is plugged into the Arduino Pro Mini (and USB port on my computer). I have the left side rails of the breadboard connected to 12V and GND. I then take the Vcc(5V) from the Arduino Pro Mini and connect it with one of the right rails on the breadboard.
With everything connected (separate 12V and FTDI cable), my code runs GREAT! Everything functions as intended.
BUT when I remove the FTDI cable and power the RAW pin with 12V, the entire circuit is doing crazy things and my code is obviously not running. I cannot figure out if I have too much voltage, or what is happening. I have a common ground between the GND's on my power supply and Pro Mini and the A4988 (i.e. all grounds tied together).Any suggestions?
Thanks in Advance,
--Neal
Thanks in Advance,
--Neal
