By antennaboy
#198997
I would like to experiment with accelerometers and Arduino. What is the smallest, most suitable Arduino and what specific accelerometer would you recommend if the accelerometer needed to be mounted on a running person or moving bike? Would the data collected by the accelerometer be stored in the Arduino memory or are there accelerometers with their own memory onboard?
antennaboy
By jremington
#198998
Accelerometers are very tiny, but need to be mounted on a "breakout board" with extra components, to be used with Arduino.
Most accelerometers are 3.3V devices, so use a 3.3V Arduino to avoid destroying them. Look for a small board, like this: https://www.sparkfun.com/products/13963
Tutorial on how to set up the accelerometer: https://learn.sparkfun.com/tutorials/li ... okup-guide
This 3.3V Pro Mini is fine: https://www.ebay.com/itm/Mini-Pro-3-3V- ... 2025725033
You will need a programming adapter to program the Arduino. Finally, worry about storing data later, you can't with this setup.
