By tim2985
#198619
Hi
Can anyone help me add a line of code to a project that is ongoing?
I have a relay switch sequence a, ab, a, abc, all off on a relay pcb connected to the Arduino and I need to add a line of code so that when the sequence is started and the relays have finished then I need a 2 second break where if you press the start button to re-initiate another sequence then it's locked out and wont operate.
The existing code is here::
#define out_a 9
#define out_b 8
#define out_c 7
#define out_d 6
#define in1 4
unsigned long delay_ms = millis();
unsigned long seq_delay=50; //delay in ms
unsigned long start_delay=25; //delay ms
unsigned long mode_delay=millis();
byte mode=0;
bool start=false;
void setup() {
Serial.begin(9600);
pinMode(in1,INPUT_PULLUP);
pinMode(out_a,OUTPUT);
pinMode(out_b,OUTPUT);
pinMode(out_c,OUTPUT);
pinMode(out_d,OUTPUT);
digitalWrite(out_a,HIGH);
digitalWrite(out_b,HIGH);
digitalWrite(out_c,HIGH);
digitalWrite(out_d,HIGH);
void loop() {
switch (mode){
//ON = LOW
//OFF = HIGH
case 1:
//a on
digitalWrite(out_a,LOW);
break;
case 2:
//a anb b on
digitalWrite(out_b,LOW);
break;
case 3:
//a on (b off)
break;
case 4:
//a on, b on,
break;
case 5:
//a on, b on, c on
digitalWrite(out_c,LOW);
break;
case 6:
//then all off
mode=0;
start=false;
break;
if (start){
if ((millis()-mode_delay)>=seq_delay){
/*Serial.print("mode ");
Serial.print(mode);
Serial.print("; a=");
Serial.print(!digitalRead(out_a));
Serial.print("; b=");
Serial.print(!digitalRead(out_b));
Serial.print("; c=");
Serial.println(!digitalRead(out_c));
mode++;
if (!digitalRead(in1)){
if ((millis()-delay_ms)>=start_delay){
start=true;
} else {
By paulvha
#198642
I have not tested it, but it might help you to get on the right track.
#define out_a 9
#define out_b 8
#define out_c 7
#define out_d 6
#define in1 4
unsigned long seq_delay=50; //delay in ms in between relay switch
unsigned long mode_delay;
byte mode=0;
void setup() {
    Serial.begin(9600);
void loop() {
    switch (mode)
        //ON = LOW
        //OFF = HIGH
        case 1:
            //a on
        break;
        case 2:
            //a anb b on
        break;
        case 3:
            //a on (b off)
        break;
        case 4:                             // ?????? again AB on ????
            //a on, b on,
        break;
        case 5:
            //a on, b on, c on
        break;
        case 6:
            //then all off
            digitalWrite(out_d,HIGH);       // ?????? d ???
        break;
    // wait in between relay mode
    if (mode > 0)
        if ((millis()- mode_delay) >= seq_delay){
            Serial.print(mode);
            mode++;
            // we have come to the end of sequence
            if(mode == 7)
                // loop for ~2 seconds
                while (millis() - mode_delay < 2000)
                    // if key pressed within the 2 seconds
                    if (! digitalRead(in1))
                        mode = 1;
                        break;
                // key was not pressed within timeout
                if (mode == 7)
                   Serial.println("loop forever");
                   for (;;);
    else
        // wait for start button pressed to begin
            mode = 1;
