- Fri Feb 23, 2018 9:01 am
#198464
Hello, I am currently working with fingerprint as to how it will input id numbers using numeric keypad. The code given below is used for my serial input numbers. Also I want it just to limit it to 5 IDs. Thank you so much!
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
while (! Serial.available());
num = Serial.parseInt();
return num;
