- Thu Feb 15, 2018 6:27 am
#198329
I got a new Sparkfun ESP32 Thing today but I so far I can't upload a sketch to it in the Arduino IDE.
I am following the steps here: https://learn.sparkfun.com/tutorials/es ... okup-guide
I have installed the ESP32 Arduino Core and tools.
I also did git submodule update --init --recursive
* I did not understand the part about FTDI Drivers and skipped it. *
The board and port show up as described in the tutorial.
I copied in the Blink sketch and tried to run it but I get the error
> A fatal error occurred: Failed to connect to ESP32: Invalid head of packet ('\x00')
My error messages:
Arduino: 1.8.5 (Mac OS X), Board: "ESP32 Dev Module, QIO, 80MHz, 4MB (32Mb), 921600, None"
Archiving built core (caching) in: /var/folders/w9/8qrgdgdd0fq8_64g2vhbv59c0000gn/T/arduino_cache_470747/core/core_espressif_esp32_esp32_FlashMode_qio,FlashFreq_80,FlashSize_4M,UploadSpeed_921600,DebugLevel_none_d13fdf85e7630712b5f36ac536480a92.a
Sketch uses 162213 bytes (12%) of program storage space. Maximum is 1310720 bytes.
Global variables use 11064 bytes (3%) of dynamic memory, leaving 283848 bytes for local variables. Maximum is 294912 bytes.
/Users/paul/Documents/Arduino/hardware/espressif/esp32/tools/esptool --chip esp32 --port /dev/cu.usbserial-DN03GFSC --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 /Users/paul/Documents/Arduino/hardware/espressif/esp32/tools/partitions/boot_app0.bin 0x1000 /Users/paul/Documents/Arduino/hardware/espressif/esp32/tools/sdk/bin/bootloader_qio_80m.bin 0x10000 /var/folders/w9/8qrgdgdd0fq8_64g2vhbv59c0000gn/T/arduino_build_795682/sketch_feb15a.ino.bin 0x8000 /var/folders/w9/8qrgdgdd0fq8_64g2vhbv59c0000gn/T/arduino_build_795682/sketch_feb15a.ino.partitions.bin
esptool.py v2.1
Connecting........_____....._____....._____....._____....._____....._____....._____.....__
A fatal error occurred: Invalid head of packet ('\x00')
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Also,
When I do “Get Board Info” I get
BN: Unknown board
VID: 0403
PID: 6015
SN: Upload any sketch to obtain it
My error messages:
esptool.py v2.1
Also,
BN: Unknown board
VID: 0403
PID: 6015
