- Sat Feb 03, 2018 5:04 pm
#198158
Hi there,
I'm running an Arduino Uno R3 with this code:
_____________________________________________________
#define trigPin1 6
#define echoPin1 7
#define trigPin2 8
#define echoPin2 12
int hit1 = 0, hit2 = 0;
int numEntries = 0, numExits = 0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(11,10,9,2,3,4,5);
void setup() {
Serial.begin(9600);
lcd.begin(16, 2);
lcd.print("Persons:");
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(13,OUTPUT);
void loop() {
lcd.setCursor(0, 1);
int duration, distance;
digitalWrite(trigPin1, LOW);
delayMicroseconds (60);
digitalWrite (trigPin1, HIGH);
digitalWrite (trigPin1, LOW);
duration = pulseIn (echoPin1, HIGH);
distance = (duration/2) / 29.1;
if(distance < 50){
Serial.println("Entering...");
hit1 = 1;
int duration2, distance2;
digitalWrite(trigPin2, LOW);
digitalWrite (trigPin2, HIGH);
digitalWrite (trigPin2, LOW);
duration2 = pulseIn (echoPin2, HIGH);
distance2 = (duration2 / 2) / 29.1;
if(distance2 < 50){
Serial.println("Exitting...");
hit2 = 1;
while(hit1 == 1 && hit2 == 0){
int dur, dist;
dur = pulseIn (echoPin2, HIGH);
dist = (dur / 2) / 29.1;
if(dist < 50){
hit1 = 0;
hit2 = 0;
numEntries++;
Serial.println("\tENTERED");
delay(250);
break;
while(hit1 == 0 && hit2 == 1){
int dur, dist;
dur = pulseIn (echoPin1, HIGH);
if(dist < 50){
hit1 = 0;
hit2 = 0;
numExits++;
Serial.println("\tEXITED");
delay(250);
break;
lcd.print(numEntries - numExits);
if(numEntries - numExits > 0) digitalWrite(13,HIGH); else digitalWrite(13,LOW);
/*lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0, 0);
delay(50);
It counts the number of people in the room and turns on a light accordingly.
It works great except it just freezes after I pass through the sensors a few times. Sometimes only 3 times before it freezes, sometimes 20.
What do I need to do to fix this problem?
Thanks in advance.
#define trigPin1 6
#define echoPin1 7
#define trigPin2 8
#define echoPin2 12
void setup() {
Serial.begin(9600);
lcd.begin(16, 2);
pinMode(13,OUTPUT);
void loop() {
if(distance < 50){
hit1 = 1;
if(distance2 < 50){
hit2 = 1;
int dur, dist;
if(dist < 50){
hit1 = 0;
hit2 = 0;
numEntries++;
delay(250);
break;
int dur, dist;
if(dist < 50){
hit1 = 0;
hit2 = 0;
numExits++;
delay(250);
break;
/*lcd.begin(16,2);
lcd.clear();
delay(50);
Thanks in advance.
