Help with very simple menu code
Posted: Fri Oct 06, 2017 9:16 pm
Hey Guys,
Long time user, but new to the forums
I'm really stumpped on a simple menu im trying to implement.
Basically its a splash screen, you press ENTER and it goes to main 1
Pressing enter again goes to Menu 2
Pressing enter again goes to Menu 3
Anytime you press the cancel button in menu 1-3 it goes to splash screen.
If anyone can help with this code, i'm just not good at looping and button pressing logic
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
int keypad_pin = A1;
int keypad_value = 0;
char btn_push;
char ReadKeypad()
/* Keypad button analog Values
up 0
down 178
enter 305
cancel 398
keypad_value = analogRead(keypad_pin);
if(keypad_value < 10)
return 'u';
else if(keypad_value > 10 && keypad_value < 200)
return 'd';
else if(keypad_value > 290 && keypad_value < 320)
return 'e';
else
return 'c';
void WaitBtnRelease()
while( analogRead(keypad_pin) < 800){}
lcd.begin();
lcd.backlight();
Splashscreen();
delay(1000);
btn_push = ReadKeypad();
if(btn_push == 'e')
WaitBtnRelease();
Menu_flow();
Splashscreen();
delay(100);
void Splashscreen()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Press ENTER to Begin");
void Menu_flow()
while(ReadKeypad()!= 'c') //if you press cancel button anytime (even inside nested menus), it will go back to very beginning
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Menu 1");
if(btn_push == 'e'){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Menu 2");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Menu 3");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Menu 4");
delay(5000); // wait 5 seconds then go back to main menu
