Code for fading in and out while also changing colour.
Oliver_Fr
Post by Oliver_Fr » Fri Sep 29, 2017 10:32 pm
Hi there Im having trouble with coding a specific task on my Arduino Uno. I've set up a simple RGB LED circuit. I'm trying to write code, which slowly increases the brightness of an RGB LED for 4 seconds, then sustain maximum brightness for 7 seconds, then slowly fade out for 8 seconds. While this is happening, it should also fade from yellow to orange and finally red. Any help would be appreciated. Thanks.
https://pastebin.com/HzsxmMuJ
Valen
Re: Code for fading in and out while also changing colour.
Post by Valen » Fri Nov 03, 2017 2:38 pm
Your code seems fine. Is there something wrong?
DanV
Post by DanV » Sat Nov 04, 2017 7:09 am
What are the issues you have.
Surely you have run the code and something happened.
Can you describe what happened and what you want it to do differently?
