- Thu Aug 31, 2017 7:08 am
#195999
I bricked my 5V/16MHz Pro Mini, and I'm struggling to decide if it's fried or fixable.
I don't have an FTDI adapter, so I program it by removing the Atmega328P-PU from my Uno. I make the following connections:
Uno-------->Pro Mini
5V---------->VCC
GND------->GND
RX0-------->RXI
TX1-------->TXO
RESET----->GRN
However, this produces the following avrdude errors:
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x40
This goes on for 10 tries. Some tutorials say to connect Uno's RESET directly to the Pro Mini RST (instead of GRN a.k.a DTR), but that produces the same error.
I've been trying to re-burn the bootloader on to the Pro Mini using these instructions http://www.instructables.com/id/Burn-a- ... -Pro-Mini/ but without any success. I'm using version 1.8.3, and I uncomment line 81: #define USE_OLD_STYLE_WIRING. avrdude throws an "invalid device signature" error.
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Any thoughts or tips? Is the Atmega328 from my RedBoard a drop-in (not literally drop-in...solderable-in) replacement for the Atmega328 on the Pro Mini?
5V---------->VCC
GND------->GND
RX0-------->RXI
TX1-------->TXO
RESET----->GRN
this check.
